Windows 2008 and running Tomcat as a windows service
mlovejoy
I have open a call with PTC about setting up tomcat as a service on 2008 Server -PTC saidthier are known issues with this do to security changes in 2008 server. I asked if they had a TAN or TPIand thier repsonse was no..and good luck.
Basically the service goes in -but when you start the Tomcat services, the service starts and then stops.
I am looking for any info on what i need to change --
Marc
6 REPLIES 6
Hi Marc,
I´m passing the same problem with "TomCat as a Service" and Windows Server 2008.
did you get it resolved?
i found this suggestion from PTC Support:
"Copy the file <java_home>\bin\MSVCR71.dll to c:\winnt\system32. After that start the Windchill and Tomcat services."
https://www.ptc.com/appserver/cs/view/solution.jsp?n=145765
, but i didn´t found the file to copy (MSVCR71.dll).
Thanks and Regards,
André
dips52
(To:mlovejoy)
Marc,
I had the same problem with Tomcat upon installing it as a service on 2008. Finally the command I used was:
ant -f config.xml installService -DJAVA_HOME= C:\java\jrse2 -DserviceName= Tomcat
I had been previously pointing the java_home path to the bin directory. Once I removed this and entered the above line it started up without any problems.
Might be the same for you, may not work....
-=D
Hi Ramirez,
Did you used the Java Installed with Windchill by PTC Installer Sollution? our did you installed a new Java Instance?
André
I tried this and used the JAVA that is is included with Windchill. It works.
Gerry
dips52
(To:mlovejoy)
Hi Andre,
Sorry I have only read this reply. Yes we did use the Java Installed with PTC Installer Sollution. I hope you've managed to fix it.
-=D
I had the same problem, I was able to resolve the issue after making changes to the OOTB <tomcat_home>\config.xml
Changes
From
