Is it possible to display a workflow string attribute as a drop down menu? I have a set list of values that I would want to select from?
Check if following helps you.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS36017
Septhen,
Please see attached document.Also if you face any issues while creating workflow variable of enumerated type refer below link
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS16646
Hope this helps !!!!
Hi Stephen,
Shreyas is right,
Hope this will work for your requirement.
BR
MKR
