Potentially...if you have your frames set, and you use your frames right away. You can go into ProE Help and search for Frames, and it will give you all the information you need to manage, adjust and use your frames.
Here is the help information on items that create frames. If you read down a little, you will see that "Removing objects from the workspace" is on the list. Hope this helps. Brian
<h1>About Workspace Operations that Create Frames</h1>All workspace actions, except refresh, create frames. You cannot create frames for actions that you cannot restore.
The following workspace actions performed in the Windchill connected mode and accessed in the embedded browser of Pro/ENGINEER or using the File menu commands in Pro/ENGINEER create frames:
Editing attributes of CAD documents
Importing objects in workspace and File > Open in Pro/ENGINEER
The addition and deletion of attachments
The locking or unlocking of objects in workspace from Actions on the workspace listing page
Creating new CAD documents and new parts using the HTML UI options in the embedded browser of Pro/ENGINEER
Save in workspace
Check in from active workspace
Undo checkout in a specific context
Addition of objects to the workspace
Update of objects in the workspace and File > Update in Pro/ENGINEER
Renaming objects in the workspace
The activation of a workspace the first time
Apply event
File > Save in Pro/ENGINEER
Workspace operations that occur on the server side, such as Modify Attribute, that affect the cache and result in cache change are also recorded as frames. Frames are not created for the following Workspace operations:
Set state
Associate and disassociate
Refresh of the workspace
Open in Pro/ENGINEER or ProductView
Opening of Information pages
Viewing and editing of workspace preferences
Accessing the Event Manager or Help
Authentication of server registration
Creation and locking of the workspace
Clear cache from server
File export from the workspace
See Also
About Recording Workspace Events as Frames
In Reply to Eric Huffman:
Gurus,
If you remove an item from workspace, say accidentally because the name
is truncated so you pick the wrong file, is there an undo or a retrieve
deleted somewhere (anywhere) to get that removed file back?
Eric
Wildfire 4.0 Datecode m090
WindChill 9.0 Datecode m030
