Hello PTC Community
I am building a custom WWGM11 package and will be pushed out to all users in the domain.
I need to know how to add server location in wgmclient.ini file so that it will automatically register when user open WWGM.
Donny
Hello dcheung,
I want the same as you describe, push the server location in the wgmclient.ini
I have read article CS245510 but it didn't work for me.
So I was wondering if you found a solution for this?
You can put this into the wgmclient.ini file
# Default server URL.
default.server.url=https://"location"/Windchill/
Setup is done for Windchill 10.2
