ant -f bin\tools.xml error
Dobi
I'm trying to add some new actions to our menus but can't compile the ActionDefinitionsRB.java.
I tried both of these:
What is missing?
Dobi
(To:Dobi)
Turns out my starting directory was off to run
So running this was the bonehead error of the day
ant -f tools.xml
Dobi
(To:Dobi)
ant -f tools.xml
PP_10699087
2-Explorer
(To:Dobi)
it seems that the issue you encountered was due to an incorrect strting directory when running the command ant -f bin\tools.xml.
 The correct command to run would be ant -f tools.xml without specifying the bin directory.
By providing the correct command, you should be able to execute the ant tool successfully and perform the desired actions or tasks specified in the tools xml file.
It's important to double-check the directory structure and ensure that you are running commands from the appropriate location to avoid such errors.
