attribute Customization in windchill
ptc-5203546
We are in Windchill 10.1.
We have an attribute called “Att A” on Part. Its drop down values are “M011”, “M022”
We have another attribute called “Att B” with values “PC01”,”PC02”.
In the part create page if the user selects the value “M011” for Att A , the value “PC01” should be auto populated for the attribute Att B. If “M022” is selected for Att A then “PC02” should be auto populated for Att B.
Is the above scenario possible to be implemented in windchill ?
Is there any simple configuration to do this or how we could implement this?
This can be done in Windchill 10.1 using datautility and some javascript/ajax function. Not with Configuration I believe. Now in 10.2, I am not sure about using attribute rules
sahmed-5
(To:g_prajeesh)
Hi Guys,
Can this be implemented in Windchill 10.2 with configuration without using Datautility and Ajax. Please respond. Thanks!
