can we perform arithmetic operations for quantity calculation in options and variants?
DhanshriTelang
7-Bedrock
Version: Windchill 13.0
Use Case: I want to perform addition of some parameters based on selection of other parameters. For E.g:-1) I have type1 having choices a,b,c with values 1,2,3 2) I have type2 having choices d,e,f with values 3,2,1 3) I have type3 having choices x,y,z with values 2,3,1 If user had chosen -a,d,x then there is one part named M should have quantity as 1+3+2=6 simillarly, b,e,y is selected then M should have qunaityt as 2+2+3= 7 and so on.
Description:
unable to perform addition while configurating quantity parameter.
Hi @DhanshriTelang,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
