change "more attributes info page layout"
rvanveerdeghem
11-Garnet
I want to change the layout of the "more attributes info page", but everything is greyed out. I can change all the other kind of layouts, except this one.
I have complete Admin rights, but this doesn't work. How can I change this layout?
Or do I need to shut windows down?
Thanks in advance.
Hi Ruben,
I guess it is very difficult to comment on this just by looking at the screen capture and without knowing what has been done so far to get rid of this.
What I can suggest is to log a case with PTC Technical Support using eSupport Portal: https://support.ptc.com/apps/case_logger_viewer/auth/ssl/log
Select Product As "Windchill PDMLink" and Technical Area "Functionality" so it will get assigned to appropriate skilled Tech Support Engineer for quicker response.
Shirish
Hi Ruben,
Are you trying to edit this for a particular soft-type?
Bhushan
