check promotion item
è吕
3-Newcomer
How do I check if the promotion target is in the other promotion notice by using the code ?
Thanks!
RandyJones
20-Turquoise
(To:è吕)
Thanks!
You can use this:
MaturityHelper.service.getPromotionNotices()
RandyJones
20-Turquoise
(To:è吕)
Thanks!
You can use this:
You can use wt.maturity.MaturityHelper.service.getPromotionTargets() to get the target objects and then as mentioned in the above response you can find related promotions notices using MaturityHelper.service.getPromotionNotices()
Bhushan
Thank you.
it works,thank you.
