config/library file naming
JohnMattson
2-Explorer
I'm beginning to load some of my configuration/library types of files
into my PDMLink test system. I'm finding that I have many different
entities with the same file name. For example, I may have a material
file, a note and a symbol file all named "plastic".
Does anyone have any suggestions for best practices for renaming these
so that they are unique. I'm thinking maybe "note-plastic.txt" and
"mat-plastic.mtl" and "sym-plastic.sym".
Thanks, John
This electronic message including any attachments ("Message") may contain information that is privileged, confidential and/or exempt from disclosure under trade secret and other applicable law. If you are not the intended recipient, notify the sender immediately, permanently delete all copies of this Message, and be aware that examination, use, dissemination, duplication or disclosure of this Message is strictly prohibited.
0 REPLIES 0
