define destination folder for pdf file created by worker
Durga
Hi All,
We have one folder "Released Drawings" which is been accessible by processing, manufacturing, supplier. It has Read & download access. We want the pdf drawing published by the worker to automatically dumped in Released Drawing folder.
What steps we may need to take.
Thank you in advance.
Durga.
5 REPLIES 5
berny2U
(To:Durga)
Hi
There is no functionality to export the result of a publish event to a folder. After publishing by the worker the files are stored back in Windchill. You need to write a Java program to export the contents of a viewable to a folder and run this program.You find plenty of examples on the knowledge base and on the web.
Durga
(To:berny2U)
Hi Berny,
Thanks for the prompt reply.
Tried searching for may be not punching the correct key words. Any references for these would be appreciated.
Durga
berny2U
(To:Durga)
Durga
(To:berny2U)
Thanx Berny
TomU
(To:Durga)
This knowledge base article provides sample code and instructions on how to do this exact thing:
https://www.ptc.com/en/support/article/CS348848
