export rule file
bruce.chastain
export rule file
Hello, I'm trying to export some documents from windchill 8.0 via the export/import manager found under product>utilities tab. What I would like to know is what is the "Export Rule File" andExport Policy File". It's mentioned in the system admin guide but I can't find what the file does or how it would be formatted. Thank you!
Well I've figured out a good bit today. Mostly about how to use the rule file. The 9.1 sysadmin guide has a good amount of information on this.
