facing problem in publishing CAD documents
ptc-4997321
Cad jobs are failing and it is giving some timeout and thumbnail generation failed error.\
Attached is log file of one of yhe faile jobs.
Hi Johin,
Seems that problem is with assembly regeneration or at least it look lite that. The weld 2944 seems to lose it ID.
Try to investigate inside the model first if that weld regenerates properly.
Best Regards
Daniel
