fix - Database and file vaults in read only mode
martin_t_brown
Thanks for all the replies! Here is the fix; (be sure to have all passwords
ready!)
run the DSMU, go to server, connect dataserver, then server, connect
intralink admin, then go to backup/restore, then select read/write mode
Thanks to all for your help!
HI folks it's me again.
Our installation of Intralink 3.2 has sat dormant for a while - still too
many people scarred to use it. But that's not why I'm writing, I am in
the process of firing Intralink back up in our office and will be upgrading
to 3.3 as soon as I'm done testing 3.2 out. I am the administrator and when
I try to check in the test objects I encounter a CONFLICT of "Database and
file vaults in read only mode"
I have gone to the Administrator section of Intralink and the Status of the
Vaults is Read/Write. The Storage Clusters are Read/Write as well.
I have gone to the Windows 2000 server and checked the attributes of the
folders. Everything appears to be set correctly.
Martin T. Brown
Alexander & Associates
307 New York Ave.
Oak Ridge TN 37830
(865) 483-3314
This electronic mail (including any attachments) may contain information
that is privileged, confidential, and/or otherwise protected from disclosure
to anyone other than its intended recipient(s). Any dissemination or use of
this electronic email or its contents (including any attachments) by persons
other than the intended recipient(s) is strictly prohibited. If you have
received this message in error, please notify us immediately by reply email
so that we may correct our internal records. Please then delete the original
message (including any attachments) in its entirety. Thank you.
0 REPLIES 0
