Hello.
I am trying to get the parent parts of a WTPart, using the WTPartHelper.service.getUsedByWTParts.
Here is what I have used:
package ext;
import wt.fc.ObjectIdentifier;
import wt.fc.PersistenceHelper;
import wt.fc.QueryResult;
import wt.part.WTPart;
import wt.part.WTPartHelper;
import wt.part.WTPartMaster;
import wt.util.WTException;
public class UsedBy {
public static void main(String[] args) throws WTException {
// TODO Auto-generated method stub
ObjectIdentifier oid = ObjectIdentifier.newObjectIdentifier("wt.part.WTPart:780838610");
WTPart part = (WTPart)PersistenceHelper.manager.refresh(oid);
WTPartMaster prtMaster = (WTPartMaster) part.getMaster();
System.out.println("Parent Part Number: " + prtMaster.getNumber());
QueryResult qr = WTPartHelper.service.getUsedByWTParts(prtMaster);
System.out.println("qr size is: " + qr.size());
if (qr.size() == 0) {
System.out.println("QueryResult is null");
else {
for ( int i=0; i<qr.size(); i++) {
WTPart usedPart = (WTPart) qr.nextElement();
System.out.println("Part Parent is: " + usedPart.getIdentity());
Here is what I get:
Here is in Windchill what I have:
How do I get the latest part version?
Thanks for your help.
Antonio
Antonio,
Use below code and let me know if works
Shreyas
package ext.sra;
import java.util.HashMap;
import java.util.Iterator;
import java.util.Set;
public class LatestWhereUSed {
public static void main(String args[]) throws WTException {
// TODO Auto-s[]generated method stub
.newObjectIdentifier("wt.part.WTPart:195983493");
WTPart part = (WTPart) PersistenceHelper.manager.refresh(oid);
} else {
HashMap<String, WTPartMaster> allMasters=new HashMap<String, WTPartMaster>();
for (int i = 0; i < qr.size(); i++) {
allMasters.put(usedPart.getNumber(),(WTPartMaster) usedPart.getMaster());
System.out.println(allMasters);
Set<String> ketset = allMasters.keySet();
for(Iterator<String> kItr = ketset.iterator();kItr.hasNext();){
WTPartMaster master= allMasters.get( kItr.next());
WTPart usedPart=getLatest(master);
System.out.println("Latest ***Part Parent is: " + usedPart.getIdentity());
public static WTPart getLatest(WTPartMaster doc) throws WTException {
WTPart part = null;
QueryResult allIteration = wt.vc.VersionControlHelper.service.allIterationsOf(doc);
if (allIteration != null && allIteration.hasMoreElements())
part = (WTPart) allIteration.nextElement();
return part;
Antonio,
Shreyas
package ext.sra;
} else {
WTPart part = null;
return part;
Shreyas,
Thank you so much!!
Very smart way to use the allIterationsOf() and to actually create an Hasmap with <Number, WTPartMaster> (not so useful using the WTPart like I did)!
I am just learning coding, but you help me understand a little better that the solution is easy and there, I just need to stop it for moment, step away from coding and look at the problem from another prospective
Again,
Thank you very much for your help!
Antonio
