how to get workflow process name when create promotion request
ptc-4038300
such as following picture,
how to get selected workflow name "Error Flow", "PE_Production..." or "RD_CAD_Promotion..."
by API.
thanks in advance.
Check below API if it works.
MaturityHelper.getPromotionPreference(wtContainerReference,targerState);
wtContainerReference-- >> container reference in which promotion request
targerState -- >> Target state for promotables
Hope this helps
Shreyas.
hi Shreyas,
I can not find API MaturityHelper.getPromotionPreference in 9.1,
could you please provide some example code, Thank you!
where are you planning to use API,
There are two forms which can be used.
below can be used in Wizard.
PromotionRequestHelper.getWorkflowTemplate(FormDataHolder paramFormDataHolder)
second is
PromotionRequestHelper.getWorkflowTemplate(WTContainerRef, State, String)
Here String can be Null  or put process name
after that you can used  getName(); method.
Hope this will help you.
