how to reload the Tree Component?
jluo
These are piecess jsp and javaScript Code.
<%@ taglib prefix="mvc" uri="http://www.ptc.com/windchill/taglib/jcaMvc"%>
<mvc:tableContainer compId="ext.reports.builder.TreeReport" height="500" />
<script>
function submitParameters() {
var params = { number : 'variable' }; //pass new variable
PTC.jca.table.Utils.reload('ext.reports.builder.TreeReport', params, true); //to reload the tree compoment and add new variable.
</script>
The javascript API 'PTC.jca.table.Utils.reload' throw exception when the store be reloaded.
//the JS file path:D:\ptc\Windchill\codebase\netmarkets\javascript\util\windchill-all-debug.js
PTC.jca.table.Utils.reload = function(id,params,removeStaleData){
//SPR 2000225. The table data gets duplicated when delete an object from folders page.
if(removeStaleData === undefined){
removeStaleData = true;
var table = tableUtils.getTable(id);
if (table !== null) {
var selectedOnlyMenu = Ext.getCmp(PTC.jca.table.getWTablePanelID(table.id) + '.selectedOnlyViewItem');
if (selectedOnlyMenu && selectedOnlyMenu.checked === true) {
selectedOnlyMenu.setChecked(false);
table.getStore().load_complete= false;
table.getStore().totalLength = 0;
var form = PTC.jca.table.Utils.getTableFormData(table);
var formData = Ext.urlDecode(form);
formData.tableID = table.id;
formData.refreshTable = PTC.jca.table.Utils.getFormattedTableId(table.id);
Ext.apply(formData, params);
if (removeStaleData) {
table.store.removeAll();
jsca.unSelectHiddenCheckboxes(id);//Remove hidden checkboxes div if we are removing data from store
table.store.fireEvent('reload');
//PTC.jca.table.Utils.reloadLegacyTable<==the function to do refreshCurrentElement
table.store.on("exception", PTC.jca.table.Utils.reloadLegacyTable, null, {single:true});
table.store.reload({
params: formData,
reload: true
I guess PTC.jca.table.Utils.reload is not support Tree table? I have use this funciton to reload table compoment and run correct.
Actually this issue is not big problem,Browser just to request Windchill server twice.
I try to compare first result page to second result pages.They are the same but unique Key.
0 REPLIES 0
