locate takes a long time
Newbie
gurus,
we are running intralink 3.4 cut m011
we have been runningit for a while and not using locate because it takes 15 min to find one single part.
ptc says that it is a dual processor problem or something like that.
does anyone have any other ideas why locate is so slow.
tia
matt riggle
siemens power generation
5 REPLIES 5
Re: locate takes a long time
I encountered this and other performance issues when testing 3.4 M011.
(We are not deployed yet.)
This is the first I've heard that dual processors were part of the problem.
My test server has only one CPU. So much for that excuse.
The good news is that M020 fixes the problems.
However, we are still using Pro/E 2001.
According to PTC's compatibility matrix, M020 does not support any build of
Pro/E 2001, (M011 does).
However, M020 is not a new build. It's a patch to M011.
How can a patch reduce capability?
I asked PTC to explain this, and am still waiting for a response.
I also told PTC that I would be willing to deploy M011 if the performance
issues could be addressed.
Still waiting.
Gerry Champoux Williams International
Lead Engineer 2280 E. West Maple Road
Information Technology Walled Lake, MI 48390
(248) 624-5200, x1216 (248) 960-2607 (fax)
- http://www.williams-int.com
Pro/E 2001, build 2004290
Intralink 3.2, build 2002270 (soon to be 3.4 M020)
ProductView 7.0, build M010
-> wrote:
> gurus,
> tia
> matt riggle
I would answer the compatibility question by saying that M020 isn't
necessarily reducing capability by dropping support for Pro/E 2001.
Supporting older versions is a QA and testing issue rather than a
software functionality issue. PTC (and other software companies) has to
draw a line in the sand somewhere when it comes to testing different
combinations of software.
Best Regards,
Bill Palm
I haven't heard of a dual processor problem, but 3.4 m011 runs much
faster than any previous release. I have a script to check out 7 of our
complete motorcycle and engine assemblies. These range in size from
about 400 objects per assembly to nearly 5000. The complete process
took on average 19:45 m:s on 3.3 2003290 and averages about 6:19 m:s on
3.4 m011.
Now for the important information, we had to change a few things out of
the box to get good performance. I'd bet that when Gerry and Matt were
searching they were using a wildcard in the search string like 123*.
Straight out of the box, m011 was terrible at this kind of search. See
TAN 128919, NOTE 2 for the fixes. We had to complete all 3 changes;
Rule, Exact and calculate statistics, to get the optimal performance.
Kevin Holle
CAD Engineer, Senior
Harley-Davidson Motor Company
It's a bit self-serving to draw the line in the sand so that half of
your customers are on the wrong side! That decision was made by PTC
long ago, well before hardly any companies had moved to Wildfire.
However, it's not like this strategy is news to any PTC customer who has
dealt with them for any length of time...
There is a bug with dual Xeon processors running Server 2003 in F000 and
M011 that causes the customisation part of the dataserver install to
randomly hang (and the DSMU as well apparently). You have to apply to
PTC for the patch see TAN129653.
