Hi team:
We have CR Description data in CR's from last year which I need to copy into the RTF longDescription field for each CR. Is there a utility for doing this?
Likewise, the Proposed Solution field.
thanks
Rick
If these are old pre-rich text Change Objects then PTC supplies a utility for moving/copying the old non rich text fields to the corresponding new rich text fields:
wt.change2.converter.richtext.ChangeSimpleToRichTextUtility
See article CS293387
