problem
I want to change a part in an assembly with an existing in Commonspace
in the workspace with INTRALINK 3.4 command duplicates, I create new assembly and then I duplicate the particular (with true flag) to be changed giving it the same name as the existing part in Commonspace
Update the part in the workspace
I correct the new assembly and its drw
done
how can I do the same with pdmEssentials
TY
Hello.
Save As allows this functionality.
If you want to be able to replace with the content in the Commonspace, then you can enable the Replace action.
Jennifer
thanks for the reply
