prevent check in of failed models
Weber
Is there a way to avoid the check in of failed 3D models im PDMLink ?
I have a config option in Creo to control save of failes models. If we allo this and we need to
how can we prevent the check in of those ? Only with modelcheck ?
Thanks for any ideas
BenLoosli
(To:Weber)
You need to configure ModelCheck and set limits as to how many errors you will allow to be checked in. If the part/assy/drawing has more than your number, the check in will fail.
