We've purchased Cognos reporting but haven't yet installed or learned to use it. In the meantime, we're relying on Query Builder. Need some help ona few specific relationships.
Please advise how to build reports that include:
a) Attachments to a Change Request or Change Notice
b)Elements of the routing / process history for a Change Request or Change Notice workflow (who approved as what Role on what date)
thank you
Folks,
The attached screenshots should give you what you need to get started.
Best regards,
Lewis
We are on Windchill 7.0 foundation, but I don't believe the relationships between workflows,workitemsand primary business objects have changed with the later releases (I am sure someone will correct me if I am mistaken).Depending on how you are using the change process you might need to use a different change object. Promotion requests are a separate object though, you will need a different query if you want to work with those.
Lewis
I am glad you were successful, I thought this might also be useful for you.
The attached file shows screenshots from another Change related query I use to provide monthly metrics to Engineering managment, it shows how to do joins between the change objects, affected data, lifecycle historyand string attribute values.
String Value Joins to ChangeRequest.
Change Request to Change Activity.
Change Activity to Change Record.
Change Recordto WTPart.
WTPart to Lifecycle History.
Good luck and best regards,
Lewis
