"publishing rules" samples for visualization...please? SolidWorks if possible?
bcavanaugh
7-Bedrock
would anyone have any publishrules.xml files they could share? I am trying to configure our CAD Workers and am struggling to find good examples...samples for any CAD "authoring application" will be helpful, so please post if you can. We are using solidworks, so any rules files involving the publishing of solidworks files to creo view, PDF, STEP would be even more helpful!
Thanks!
Barry
Hi, this exemple produce PDF and step
<rules xmlns="http://www.ptc.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.ptc.com PublishRulesSchema.xsd" evaluate-rules-on-republish="true">
<authoring-application name="PROE">
<additional-files name="part_files">
only default='true' files will be generated at this time
<file display-label="STEP" type="step" default="true" output-prefix="step"/>
</additional-files>
<additional-files name="asm_files">
</additional-files>
<condition name="is_part">
<attribute name="epmdoc_name" regex=".*\.prt"/>
</condition>
<condition name="is_asm">
<attribute name="epmdoc_name" regex=".*\.asm"/>
</condition>
Following conditions are evaluated based on the order they appear in this file
<if condition="is_part">
<publish on="checkin" display-label="Publish part - checkin" additional-files="part_files"/>
<publish on="create-representation" display-label="Publish part" additional-files="part_files"/>
<publish on="schedule" display-label="Publish part schedule" additional-files="part_files"/>
</if>
<if condition="is_asm">
<publish on="checkin" display-label="Publish assembly - checkin" additional-files="asm_files"/>
<publish on="create-representation" display-label="Publish assembly" additional-files="asm_files"/>
<publish on="schedule" display-label="Publish part schedule" additional-files="asm_files"/>
</if>
</authoring-application>
</rules>
For solidworks, parasolid files working good
