retrieve maturity history of an object by API
HenriMarchal
7-Bedrock
I don't find the java helper or utility to retrieve maturity history of a WTObject.
We can have these data with the GUI in the third level navigation tab. It is in History/Maturity.
I figured out in actionModels.xml that this button calls a UI Component named "THIRD_LEVEL_HISTORY_MATURITY" but I don't know what is called behind...
Do you know how I can retrieve this maturity history via API ?
Thank you
I didn't look into them but there's a MaturityHelper and service in the wt.maturity package.
It was not good (this helper appears useful for baselineItems and the Promote action).
But I found QueryResult result = com.ptc.windchill.enterprise.history.HistoryTablesCommands.maturityHistory(wtObject);
It is fine.
