sqlplus login issue
gkemner
7-Bedrock
sqlplus login issue
After installing a patch to my oracle 10g database I get the following error when trying to log into sqlplus
ORA-01034: ORACLE not available
ORA-27101: shared memory realm does not exist
Any ideas?
Thanks!
It seems like the Database is closed.
Login as sqlplus /nolog and then as sysdba to start the database.
The full commands would look like below
sqlplus /nolog
connect sys/change_on_install as sysdba;
Connected to an idle instance
Startup;
