The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
undo check out problem.
HarikrishnanR
3-Visitor
hi all, i anm getting an error message while doing undo check out . please see the error message and suggest. "The returned query result has exceeded the query limit, and only 130,000 result returned." thanks, hari...
hi, you can try increasing the 'sizelmit' value in the ptcldap.conf file in Aphelion. regards, rohan
