workflow condition check for populated role
vmcdaniel
Hey All,
I'm trying to check the promotion request workflow if a role was populated during the initiation of the promo request, in the wizard; or if I need to branch off to a Setup Participants activity.
I'm adding a condition node in the workflow with the below, but it does not work. Although it should look familiar 🙂
Any code or tips for me?
Thanks Vaughn
boolean provider = false;
wt.workflow.engine.WfProcess wfprocess = (((wt.workflow.work.WfAssignedActivity)self.getObject()).getParentProcess());
java.util.Enumeration roles = wfprocess.getRoles();
while (roles.hasMoreElements())
wt.project.Role role = (wt.project.Role)roles.nextElement();
java.util.Enumeration participants = wfprocess.getPrincipals(role);
if (participants.hasMoreElements())
if (role.getDisplay().equalsIgnoreCase("Approver")) provider=true;
if (!provider)
result="SetupApprover";
}else{
result="AlreadySetup";
Thanks for the help Jeff, Brian, Randy
Here's what is currently working for me:
result="Good";
boolean provider1 = false;
boolean provider2 =false;
boolean receiver = false;
System.out.println("Initialized Provider1 = " + provider1 +" Provider2 = " + provider2 + " Receiver = " + receiver);
wt.workflow.engine.WfProcess wfprocess = ((wt.workflow.engine.WfProcess)(self.getObject()));
if (role.getDisplay().equalsIgnoreCase("Approver")) provider2=true;
if (role.getDisplay().equalsIgnoreCase("Contributor")) provider1=true;
System.out.println("Evaluated Provider1 = " + provider1 +" Provider2 = " + provider2 + "Receiver = " + receiver);
if ((provider1)&&(provider2)) result="Good";
else
result="null";
Be well,
Vaughn
