wpa flex field viewing in UI
jbergstrom-2
Is it possible to view WPA flex fields via the UI?
How can you edit the UI to support this?
mjasti
(To:jbergstrom-2)
Yes, it is possible to view the WPA flex fields in UI and these flex fields are available only on few main business objects like Company part, supplier Part, substance etc.,
Detailed information on configuring flex fields is available in Chapter 9 of WPA configuration guide which can also be found in /productanalytics/help/
