wt.pom.DatastoreException: A SQL error has occurred for the statement "UPDATE ScheduleQueueEntry SET
KanifG
I am getting this error frequently, Method Server goes into loop and never come back after heavy logs size.
Error is:
commonScheduleQueue.SchedulingThread: ERROR : wt.queue.ScheduleQueue.commonScheduleQueue -
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: (wt.pom.pomResource/0) wt.pom.PersistenceException: A persistence error occurred. System message follows:
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: Nested exception is: wt.pom.DatastoreException: A SQL error has occurred for the statement "UPDATE ScheduleQueueEntry SET args=?,classnamekeydomainRef=?,idA3domainRef=?,endExec=?,entryNumber=?,entryOwnerIsNull=?,classnamekeyB5=?,idA3B5=?,failureCount=?,inheritedDomain=?,datelock=?,classnamekeyA2lock=?,idA3A2lock=?,notelock=?,classnamekeyA6=?,idA3A6=?,classnamekeyA5=?,idA3A5=?,scheduleTime=?,securityLabels=?,startExec=?,statusInfoIsNull=?,codeC5=?,messageC5=?,rescheduleTimeC5=?,targetClass=?,targetMethod=?,markForDeleteA2=?,updateStampA2=?,modifyStampA2=?,updateCountA2=updateCountA2+1 WHERE ((idA2A2 = ?) AND (updateCountA2 = ?))". Database system message follows:
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: Nested exception is: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:440)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:396)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:837)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:445)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:191)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:523)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:207)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at oracle.jdbc.driver.T4CPreparedStatement.executeForRows(T4CPreparedStatement.java:1010)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1315)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3576)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at oracle.jdbc.driver.OraclePreparedStatement.executeUpdate(OraclePreparedStatement.java:3657)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeUpdate(OraclePreparedStatementWrapper.java:1350)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at wt.pds.SQLDatabasePds.updateList(SQLDatabasePds.java:2426)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at wt.pds.SQLDatabasePds.update(SQLDatabasePds.java:299)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at wt.pom.PersistentObjectManager.update(PersistentObjectManager.java:2638)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at wt.pom.PersistentObjectManager.update(PersistentObjectManager.java:822)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at wt.fc.StandardPersistenceManager.update(StandardPersistenceManager.java:1356)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at wt.fc.StandardPersistenceManager.update(StandardPersistenceManager.java:1337)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at wt.queue.ScheduleQueueEntry.update(ScheduleQueueEntry.java:449)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at wt.queue.ScheduleQueue.execEntry(ScheduleQueue.java:346)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at wt.queue.ScheduleQueue.execEntries(ScheduleQueue.java:412)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at wt.queue.ScheduleQueueThread.processReadyEntries(ScheduleQueueThread.java:257)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at wt.queue.ScheduleQueueThread.run(ScheduleQueueThread.java:75)
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: ERROR : wt.queue.ScheduleQueue.commonScheduleQueue wcadmin -
Sat 11/17/12 15:34:45: commonScheduleQueue.SchedulingThread: at wt.queue.ScheduleQueue.execEntry(ScheduleQueue.java:311)
jessh
(To:KanifG)
I'd ask technical support, but my recollection is that this is an indication of an Oracle bug fixed in an Oracle patch.
We got this BUG few months ago.
The bug is that if you have the same table in multiple schema, sometime Oracle get lost. We got a patch from Oracle support.
You should be able to find the bug easily on mysupport.
Thanks a lot, seems like i need to install the Oracle patch to fix this..
ganesh_k
3-Newcomer
(To:KanifG)
I am also facing the same issue(I am using Oracle 11.2.0).
Can anyone of you tell me the patch version that will fix this issue?
