wvs seems to behave abnormally.
CHASEONHO
18-Opal
Creates a visualization when you check in a model file from Creo.
However, the visualization looks abnormal like a photograph.
If you activate the visualization by hovering the mouse, the graphic will break as follows.
It looks different from what you see in Creo View.
I have reinstalled the CreoView adapter and client via PSI.
I also installed the adapter and creo for the worker again.
But the results do not change.
Could you fix it?
thank
P.S. Attach model file used for visualization
0 REPLIES 0
