Hi, after a hard drive crash I managed to save my workspace data (.wf folder). It replaced the hard drive and copied across all data including the .wf folder. I then reinstalled creo2 on the fresh hard drive but now don't know how to access the old workspace. Any help much appreciated.
thanks
Hi Padraig...
You cannot take your .wf from one hard drive and move it to another... at all. There's something in the way the workspace is created that's literally locked to your specific hard drive. We used to hit this problem all the time. Our IT folks were swapping out hard drives and simply copying over all user data to the new one... which made it impossible for our users to access their workspaces.
Luckily there are two techniques I can share to help you. First, it helps to know if you're working in Wildfire 5.0 or Creo. I'll assume Wildfire 5 but I'll try to give Creo guidance ,too! This does make a difference as the techniques are slightly altered depending on your version.
Option #1:
This first option is sort of a nifty trick we learned by trial and error. It works for most times when a workspace is corrupted (but not all). However, since your workspace isn't really corrupted, it should work for you in this situation.
Option #2:
The second option involves downloading and installing the Windchill Recovery Tool developed by Ron Thellen. He's shared this tool free of charge on the PTC/User website. You'll need to register to use PTC/User (it is an independent user group). You can find the site at ptcuser.org
Once you've registred and logged in, you can use this link to find the public downloads section of the site. Here you'll see both the 32bit and 64bit versions of the Windchill Recovery Tool. Here's the link: http://portal.ptcuser.org/p/do/si/topic=67&type=0
I realize there's quite a bit of data here. By now you'd think someone would have asked this question and we'd have a document created just for this kind of occurrence. Please write back and let us know if this worked for you. I'm sure these procedures could help many other people, too.
Best regards,
-Brian
