Plotting / Calculating probability distributions
I´m currently using MathCad_Prime6.0 trial version as I need to edit some of my old scipts calculating statistic methods from my former studies. So I use those scripts as I set them up 5 months ago, calculating probability distributions and convolutions of them.
Trying to plot them in a diagram, identically according to e.g. >>https://support.ptc.com/help/mathcad/r6.0/de/PTC_Mathcad_Help/example_prob_dens_and_cum_prob_dist.html#<<, plotting does not work graphically (there is only a single point in the plot depending on the diagram type, for instance), nor is an error message displayed. When changing the diagram type, the scaling, the variables or the functions nothing happens either. So is this connected to the trial version licence or am I missing something else? Unfortunately I cannot add a screenshot, but its excactly the typing of the example shown in the link. Maybe you can give me a short support. Thanks a lot in advance! Marco
