3-Newcomer
Windchill 13.0.2.0: Intermittent Timeouts Experienced During Batch Requests to WRS Endpoints
Version: Windchill 13.0
Use Case:
We are currently hosting Windchill on a Kubernetes cluster deployed in Azure AKS. The setup consists of 4 Method Server pods and 15 Background Method Server pods, with the following resource configurations:
Method Server Pods:
Resource Limits:
CPU: 500m
Memory: 512Mi
Resource Requests:
CPU: 250m
Memory: 256Mi
Background Method Server Pods:
Resource Limits:
CPU: 7 cores
Memory: 30Gi
Resource Requests:
CPU: 500m
Memory: 10Gi
We are running batch requests following the guidelines outlined in the Windchill REST Services documentation (https://support.ptc.com/help/windchill_rest_services/r1.6/en/index.html#page/windchill_rest_services/WCCG_RESTAPIsBatchSupport.html). Our workload involves performing approximately 25 batch requests across 10 threads simultaneously.
Sample Requests:
Below are examples of the batch requests being executed:
--batch_request
Content-Type: application/http
Content-Transfer-Encoding:binary
GET /Windchill/servlet/odata/v7/ChangeMgmt/Changeables('OR:wt.part.WTPart:123*******')?$select=Number,Version&$expand=ResultingByLinks($expand=ResultedByObjects($expand=AffectedObjects($select=Name);$filter=isof(PTC.ChangeMgmt.TypeUsageChangeTask);$select=Name,State);$select=TARGETUSAGEMATURITY,CreatedOn;$orderby=CreatedOn%20desc) HTTP/1.1
--batch_request
--batch_request
--batch_request
Description:
We are encountering intermittent timeouts with our batch requests. When a timeout occurs, we retry the request up to 3 times, with a 10-minute wait between retries. Despite being generous with the timeout duration, the issue persists intermittently.
From our analysis of pod performance metrics, it appears that the pods may be overloaded or busy at the time the requests are executed. However, we want to ensure there are no other underlying causes for these timeouts.
Key Concerns:
  1. Could there be other factors beyond pod load causing these timeouts?
  2. Is there anything in our request structure or execution pattern that could be contributing to the issue?
  3. What additional steps can we take to mitigate these timeouts on our end?
Additional Context:
Given that we already allow a 10-minute timeout, we are questioning if the requests we make (e.g., expanding multiple nested entities or filters) are particularly resource-intensive or unreasonable. We aim to improve system reliability and reduce the occurrence of timeouts while ensuring efficiency in our operations.
We would appreciate guidance on:
  • Identifying potential root causes for the timeouts.
  • Optimizing our request patterns or system configurations.
  • Any best practices to manage system load or improve Windchill's performance.
Catalina
Community Manager
Hi @TM_10752518
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
joe_morton
Have you opened a Support Case with PTC?
3-Newcomer
Hi, thanks for the reply. No I haven't.
Catalina
Community Manager
Hi @TM_10752518,
If so, please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
