How to join 2 Infotables on their common columns
Sometimes you need the values from different ThingTemplate members in ONE grid. Therefore it would be great, if you can join 2 "GetImplementedThingsWithData" results into a common one. Here a script that works generally as long as you don't mess with datatypes on same column names.
I'm very interested, if someone can find a much easier solution. The Union function was the only one I found suited for the task, but this needs preparation of the infotables upfront.
Input:
Table1 :Infotable
Table2: Infotable
Output: Infotable
Here the "Snippet":
// Define params for an Infotable to hold column names
var params = {
  infoTableName: "field" /* STRING */
// Define column 1
var newField = new Object();
newField.name = "field";
newField.baseType = 'STRING';
// Two 1 columns Infotables to store the field definition;
var field1 = Resources["InfoTableFunctions"].CreateInfoTable(params);
field1.AddField(newField);
var field2 = Resources["InfoTableFunctions"].CreateInfoTable(params);
field2.AddField(newField);
// Define the cell to add to Infotable
var myField = new Object();
myField.field = "";
myField.baseType = "STRING";
// Loop through Table1
var dataShapeFields = Table1.dataShape.fields;
for (var fieldName in dataShapeFields) {
  logger.debug('field1 name is ' + dataShapeFields[fieldName].name);
    myField.field = dataShapeFields[fieldName].name;
   field1.AddRow(myField);
// Loop through Table2
var dataShapeFields = Table2.dataShape.fields;
  logger.debug('field2 name is ' + dataShapeFields[fieldName].name);
   field2.AddRow(myField);
// Using inner join functionality to filter only the values that exist in both
var params = {
  columns2: "field" /* STRING */,
  columns1: "field" /* STRING */,
joinType: "INNER" /* STRING */,
  t1: field1 /* INFOTABLE */,
t2: field2 /* INFOTABLE */,
  joinColumns1: "field" /* STRING */,
  joinColumns2: "field" /* STRING */
var commonFields = Resources["InfoTableFunctions"].Intersect(params);
// Loop over the result to build a search string
var commonColumns = "";
var tableLength = commonFields.rows.length;
for (var x = 0; x < tableLength; x++) {
  var row = commonFields.rows;
  commonColumns = commonColumns + row.field + ",";
// Reduce Table1 to match only common columns
var params = {
t: Table1 /* INFOTABLE */,
columns: commonColumns /* STRING */
var result1 = Resources["InfoTableFunctions"].Distinct(params);
// Reduce Table2 to match only common columns
var params = {
  t: Table2 /* INFOTABLE */,
var result2 = Resources["InfoTableFunctions"].Distinct(params);
// At the END JOIN the tables together (does not work if colums are different)
var params = {
  t1: result1 /* INFOTABLE */,
  t2: result2 /* INFOTABLE */
var result = Resources["InfoTableFunctions"].Union(params);
22-Sapphire I
Not sure if it would be faster, but you could just add the two together and then run a Distinct
Something a tat crazy but would work too, set up a DataTable with the proper Primary key and just do AddOrUpdate with both tables, this of course means you have it permanently stored.
Hi @PaiChung
Can I do it without a DataTable?
I have only one Infotable( created from a datashape) from which I have to create a lookup for  one of the fields...and then based on that particular field selection represent rest of the data in the mashup.
Also, explain how  I can do it with the help of list /dropdown widget...
22-Sapphire I
If all the info even the info after selection is in the same infotable, I would just return the whole infotable to the mashup.
And then you can show the Items in a drop down and based upon selection use selected row information to display the associated information.
