Jan 23, 2012 8:56 PM UTC
Changing "Released" CAD Data in PDMLink
Users, Abusers and Downtown Cruisers; I have two questions forthe users that are working with Pro/E and PDMLink. I am wondering if y'all are willing to share how your company handles these two scenarios in PDMLink:Non-Solid CAD Changes After Released: The models and drawing are at a RELEASED state, but there is something that needs to be changed or added in the 3D models. For example, you need to hide a Layer, add a Datum, fix a frozen or failing component's assembly constraint, add a Simp Rep, etc. We do not want to REVISE the model to bump it back to a state where it can be Checked Out, changed and Checked In. We are changing the model only, not the drawing. How are you handling this at your company? Make Minor Changes to A Drawing (or Model) During the Approval Process: The drawing is going through the process of being reviewed/approved. After ~10 people have reviewed it and approved it (Engineering, Manufacturing, Purchasing, etc.), one of the people in the process (Quality)finds a typo, or a layer that should have been hidden, or whatever. If the drawing is rejected, the review process has to start all over once it is fixed, causing a delay. How is your company handling this?Hopefully this is not too much of an "emotionally charged" issue for a Monday afternoon. Any input is appreciated! Thanks, Andy B.
Feb 1, 2012 4:35 PM UTC
Tim,
You have a very good point and the short answer for me is NO.
I would love to say that I can trust my users, but I know from experience that if they can get around something, they will. It's like telling a kid not to get a cookie from the cookie jar. It becomes their mission in life to get that cookie.
Having a system that locks down the correct process is key but not having any flexibility or options on how it does it is what I think can be improved. If you want to keep people out of your car, you can weld the doors shut and weld sheetmetal over the windows. That's a little extreme and a different approach can give you the security you need while making it practical for everyday use.
Windchill currently locks everything down so tight, that you don't have the flexibility to do real world things with your cad data and not cause some drastic revision change in the process.
Here is something that just happened today. We have a released product. QA wants us to provide them a Validation report that compares our Casting to the 3D model. We use Geomagic Qualify and our 3D Laser Scanner for this type of work. We need to add a coordinate system to the 3D model that Geomagic Qualify can use for the purpose of doing the Validation and getting the report back to QA.
Adding a coordinate system does not change the Form, Fit or Function of our product. In fact, it has NOTHING to do with the product we sell, but we are wanting to do some internal studies to make sure our product is the best quality possible. No one can convince me that adding a coordinate system for this purpose should force a Revision change on the product.
Windchill needs more flexibile options for handling this type of everyday work. The people at PTC are sharp individuals and their must be a way to make Windchill secure while giving it some felxibility. I hope they are working on it.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
Feb 1, 2012 4:42 PM UTC
Having read through this thread, I must bemisunderstanding something, so please forgive me if this is the case.
What is it exactly that we're asking the software to do? I ask because the general feel seems a lotlike the complaints are all over the map describing a problem, specifying how to use the software to overcome the problem, then saying the software can't overcome the problem.
The ability to change drawing/model for minor details after it's released -- details like adding a datum axis or changing the color of a single surface for better contrast -- without increasing the revision level? Doesn't that exists with the ability to set up individual accounts or groups or roles to check those released objects out? The Product Manager role springs immediately to mind. It doesn't have to be a system administrator; just pick your most responsible software user and train them when it's okay to do this or not to do it.
If no user is responsible enough with the software and the internal company processes doesn't address this issue, no software is going to change that.
Someone mentioned having the adminmanually set state to allow users to check out, modify, then check in, but that simply gives the user a sort of ad hoc product manager permission, just for those few files instead of for everything within that product. If no user can be trusted (again, no software is going to address this) with product manager permissions and the admin is setting state on individual files, a workflow can be created to change parts to a state that allows modification, then changes them back upon completion. A manager fires off the workflow, it changes state of objects within it, the assignee checks them out, modifies and checks them in, finishes the assignment and the workflow changes the state back to released. This would limit the assignee to only changing those specific files.
What about the ability to track these "less significant" changes? If they're so insignificant that you don't want your vendors requoting a new revision (usually increasing price along the way) or your customers getting confused, just don't track them. If they have to be tracked, iteration history will do that for you. It's also my opinion that if they're significant enough to be tracked, then they're signifcant enough for a drawing/model revision. Revising is how significant changes are tracked.
This is opening another can-o-worms, but hey, why not bring it up? I was previously exposed to a different methodology concerning revisions. If the form, fit or function changes in such a way that the part in question is no longer 100% backward and forward interchangeable, assign a new number. In this way, when the customer says he has P/N 123456, it doesn't matter what revision he receives as replacement, it's always interchangeable. Then revising the drawing for minor changes is irrelevant from that standpoint. Of course this doesn't help with vendors requoting for simple changes like fillet size or other changes that don't affect that forward and backwardinterchangeability.
That tangent aside, what else are we looking for aside from the ability to check out released objects for "less significant" changes? Because that exists within the software as-is, in multiple ways. Since that ability exists, is this boiled down to needing to track these "less significant" changes more easily than viewing the iteration history? Or is it simply a matter where users cannot be trusted, so the admin is doing all this work (and feeling frustrated that users can't simply do this work correctly)?
Feb 1, 2012 4:45 PM UTC
We're not on Windchill, and I've been following this thread with interest.
We're currently on a third party PDM that does NOT allow bumping revisions
/ versions without a change. ANY change, requires a revision level
change.
On the surface this may sound bad, but in reality, we like it that way.
It removes ALL loopholes from what's a change and what isn't. If you
touch it, and make ANY change, that's a change folks.
I wouldn't go so far as Timothy to say is it an issue of can you "trust"
your users, but I'll guarantee you that if there's a loophole that can be
exploited, and changes can be made without revisions, users will find that
and exploit it. I don't think that users would maliciously use this
functionality to bypass changes, but I think that they would make changes
that may not fit your companies criteria for what a change is and what a
change isn't.
And, to Chris's point, my companies position is that if you add ANYTHING
to a model, you're making a change. Our models are our bible. With our
system there is no room for interpretation of what's right and wrong,
what's allowed and what isn't. It's pretty cut and dried. But, I can
also see how other's may not like this type of system, but I guess that we
don't know any different because it's always been that way here.
YMMV.
Feb 1, 2012 4:56 PM UTC
They have not abandoned this at all.
In Windchill you have your revision letters/numbers and an iteration number for each time you save that file.
Just like Intralink 3.x, once a file is released, it prevents normal users from modifying the file. As an admin, I can check out, make a minor change and check back in the same revision level part, juts it will have a higher iteration number.
The issue comes down to who has the rights to make a change to a released file and how much are they trusted!
Thank you,
Ben H. Loosli
USEC, INC.
Feb 1, 2012 5:00 PM UTC
As an administrator, you can add the coordinate system and check the changed file back in at the same revision level.
Thank you,
Ben H. Loosli
USEC, INC.
Feb 1, 2012 5:04 PM UTC
Don,
You obviously know more about Windchill than me. We don't even have it up and runing yet. Let me be clear in that PTC did find a solution to minor changes and how to control them. The process requires manual intervention and users have shown that they make many mistakes when allowe the feedom to do so. The solution provided to us will require the "Administrator" to bump up the revision level as needed, but the end user can choose to check the product in as a minor revision regardless if they changed the product drastically.
There is a way to make it work, but it opens up room for error which is why we purchased the software to begin with.
Can there be a more intelligent way of having the system provide the flexibility while automating it at the same time? I have no clue and hope someone here can share a solution.
The lack of flexibility that I mentioned in the past is based on breaking automation and control in order to make things work as they should.
Is there an automated way for Windchill to notify me for approval before an end user check's something back into the system as "Released"? If there is, I would love to learn more about it. At least this way the manual process requires approval and can prevent the end user from just checking things in.
P.S. I am a veteran Pro/ENGINEER (Creo) user with over 18 years experience. I know almost nothing about Windchill and will start my journey to learn it this year. So any help from the guru's would be great.
Feb 1, 2012 5:05 PM UTC
Thanks, Ben, for that clarification. That is good to know.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
Feb 1, 2012 5:10 PM UTC
Ben,
As the "Administrator" to be. I would not be the person doing the actual work on the model. The Engineers' will. Is there a way to have Windchill 10 request approval from me before a user can check something into the system at the "Release" state?
If so, this would prevent Chaos. My biggest concearn is that the end user can check it in and choose not to notify me that a new Revision letter is required.
We have two "Admins" with privileges for just these occasions, and to
Maintain the integrity of our Family Tables.
They will review the file and force the check-in - and this only happens
once in a great while.
BUT
There will always be the "clever" who manage to try and cheat the system -
fortunately for us in our organization, we have no such clever individuals.
This makes life so much easier.
Regards
Anthony R. Benitez
Senior Mechanical Designer
Drafting Supervisor
Applied Research Laboratories
The University of Texas at Austin
Feb 1, 2012 5:14 PM UTC
I agree that it's either changed or it isn't. And remember, you will
probably have to formally document (and explain to an auditor) why/how
you are changing your CAD models and adding a manual step to the PDM
system to either 'roll back' the rev, or hold back the released status
of the models.
In the case above where a CSYS was added for inspection would fit in
well with my idea to create a new derivative model using an inheritance
feature for this purpose. The parent would not change revisions, the
derived model would be free to revise for internal reasons, and
everything has a history and is rev controlled and easy to explain to an
auditor.
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
