Read XML data and add to infotable
This is my xml file
This is my code -
var xmlDocument= me.XMLReceivedMessage;
// create info table from data shape
var params = {
infoTableName : "infoTable",
dataShapeName : "US_NRV_Factory_Dash_QULIS_DataShape"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(xmlParserTable)
var infoTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
// iterate through xml and add to info table
for each (var tag in xmlDocument.DataArea.QualityDeviationRemark) {
var newRow = Object();
newRow.ChassisNumber = tag.DataArea.QualityDeviationRemark.ChassisNo;
newRow.CreationDateTime = tag.DataArea.QualityDeviationRemark.CreationDateTime;
newRow.ProblemType = tag.DataArea.QualityDeviationRemark.ProblemType;
newRow.ProblemDetails = tag.DataArea.QualityDeviationRemark.ProblemDetails;
newRow.ReportingArea = tag.DataArea.QualityDeviationRemark.ReportingArea;
infoTable.AddRow(newRow);
// return info table
var result = infoTable;
Can someone please help me. It says no data each time I execute.
