Hi!!
Currently 2d takes up a lot of time. Other than templates is there anything else that can be done to reduce the time required for 2D??
1. Like creating a detailed view
2. The holes which are not coming in hole chart, add the line item in holechart and do the dimensions in respective views
3. Add fitting dimensions to the views
4. Give cut bearing dimensions and make rectangular box for it
Or anything else which can be used to reduce the time taken for 2D drawings will help.
If you have a repeatable set of clicks you can create Mapkeys to automate the clicks. Just depends how often you do something if it's worth creating a Mapkey. Here's a discussion about how to create Creo Mapkeys.
Thank you for your response!!
Hi @sparulekar,
If Ihoogeveen's response answers your question, you could mark that post as an Accepted Solution. Doing this could greatly help other community members with the same question find their answer quickly. Thank you both your participation on the PTC Community!
