3D dimensioning, ASM
Vidhyadhara
I have couple of questions on 3D Dimensioning (annotations)
1. In assembly file how to call/insert an ASM BOM (should be associative) using 3D Dimensioning (annotations)?
2. Which neutral file format supports export of the 3D Dimensioned part file?
thx
I haven't seen any possible way of including BOM as annotation.
Even 3D dim. as annotation is not possibe to export through any neutral format.
Kevin
(To:Vidhyadhara)
Creo Elements/ Pro *.neu file supports the export of 3D annotations.
