Has anyone run into an issue with a 64 bit machine crashing ProE when
you try to pull up a large assembly? I tried the same assembly on a 32
bit machine and it pulled it up just fine.
ProE WF 3.0 64 bit m120
Michael Wimberly
Engineering Applications Support Specialist II
Security & Survivability
BAE Systems Land & Armaments
9113 Le Saint Drive
Fairfield, Ohio 45014 U.S.A.
(513) 881-4843 Direct
(513) 881-5087 Fax
(513) 881-9800 Main
P Before printing, think about the environment.
