A few Creo Parametric Simulate Enhancement Requests
danderson
I hope some people will find the following ideas of value so they can be added to the software in the very near future.
Most of these I'm sure others have thought of in the past.
Please vote on if you feel they are of value.
Add Ability to Creo Simulate to Copy Simulation Features From One Part or Assembly to Another Part or Assembly
Add Ability to Creo Parametric Simulate to Copy Components and or Sub Assemblies and related Simulation Features from one Assembly to Another Assembly
Add Ability to Component Repeat Placement to Include Duplicating Simulate Features Like Contacts, Ground Springs and Preloads (pattern also)!
Isolate Component(s) By Hiding ALL Non-Selected Components for Temporary Effect (No Layers or Reps)
Add Ability to Select Creo Simulate Parametric Features in a Model or Assembly and Right Click to Locate or Highlight in Model Tree
Allow Creation and Editing of Simplified Reps and Changing States While in Creo Simulate / Mechanica
Create Simulate Results Window Templates from Design Study related to Assembly Analysis with multiple load cases and windows
reo Parametric Simulate - Design Analysis Flexible Dimensions (model dimension variation driven from analysis) and Spec…
Creo Simulate - Layer Control While Defining a Strain Vector Plot of Only Selected Surfaces and Abilty to display vectors on only surfaces in dirrect view.
Add ability to Creo Simulate Fasteners to Work With Tapped Hole Lead in Chamfers & Counter Bores
Improve and or Add Ability to Copy / Duplicate Load Sets, Loads, Constraints, Forces and Improve Naming and Function Consistency
Creo Simulate - Allow you to select a Model or Sub Assembly in the Main Window and Right Click to Open It.
Creo Parametric Simulate - Add Ability to Edit Model Feature Dimensions While in Simulate
Mechanica / Simulate Edit Load Set Description
Creo Parametric Simulate - Delete Multiple Analysis
Creo Simulate / Mechanica - Add ability to use Fluid Cavities with displacement equations
Don Anderson
Don't forget to vote on your own ideas, Don!
