Adding another dimension value to a dimension
ptc-1701983
How is it possible? For example the dimension is the diameter of the hole and I want to add the depth by referencing the depth dimension, but without adding a cut away to another drawing view. It would read something like 4.00 x 10.00 DEEP where 4.00 is from @D in the dimension text box and 10.00 is from ??? Thanks.
Richard You can add that other dimension, but you must find out what the dimension's name is. Select the depth dimension and find the name under properties. Then in your other dimension add the text &d32 (insert the real name) after the other dimension and that should get the result you are looking for. Eric
Magic. Thank you.
