Is it possible to add a template to the New File Option window so I would not have to always use the Browse option and find the template?
For clarification, the New File Option window is found by:
New -> Part (uncheck the "Use default template) -> the New File Option window appears with the default template listed. This is where I want to add the new template.
Yes
Either put your template in the folder with the other default templates (if a PTC system folder, not recommended) or define start_model_dir in config.pro and put your templates in that folder. Still need to hit browse, but it will then open your folder with your templates.
Yes
