If I remember, you can add parameters to multiple models, but I forgot how. I have about 300 models/ assemblies that I need to add two parameters to. What is the quickest way to do this?
Using WF4
Multi-select the models in the model tree and right mouse click>Edit Parameters. You might need to add them to the top level assembly seperately if thats one of the models that needs them.
