A picture is worth a thousand words. That’s why companies invest significant time and money into building a physical prototype that can be photographed for use in marketing materials or consumer testing.
Pro/ENGINEER Advanced Rendering Extension (ARX) allows you to produce photorealistic 3D product images for use in design reviews, marketing collateral, technical documentation, user manuals, and product packaging–without having to build a prototype. And, as your design concept changes and evolves, you can easily update your images without creating a new prototype, thus reducing costs significantly.
With Pro/ENGINEER ARX, you can render images faster, with amazing realism. Simply select a specific material and apply photo-quality properties like a smooth, glossy finish or a rough, matte finish. You can represent the product‘s intended environment more realistically with Pro/ENGINEER ARX than with any other application.
You now have the flexibility to create the perfect effect with the power to directly manipulate the lighting through 360° of rotation. You can also create a suitable environment for the product to be rendered in, for example, an outdoor scene or an office desktop. Additionally, you can apply special effects like textures, reflections, shadows and depth of field to enhance the final image. These advanced capabilities not only create images that impress consumers, but they also give you back time to optimize your design, and more budget to produce collateral that will generate both sales revenue and excitement around your product.
With photorealistic images of the product in its actual environment, design reviews are much faster, and generate more enthusiasm. 3D-rendered images can also be used for consumer testing, and for tailoring the product and product launch to ensure success–at a significantly lower cost. High-quality images can also be used in technical publications, such as product documentation, white papers and user manuals.
Pro/ENGINEER ARX will enable your product to break into the marketplace, not only with accurate promotional material, but with stunning visuals showcasing all aspects of the product.
Advanced Lighting Capabilities
Simulate a Wide Range of Materials
Define the Product Environment
Special Effects
Language Support
English, German, French, Italian, Spanish, Japanese, Chinese (Simplified and Traditional) and Korean
Platform Requirements (consult www.ptc.com/support)
Microsoft Windows (7, Vista and XP, 32 & 64bit)
UNIX platforms (Solaris 10 64bit)
Hi John
This ARX seems to be very capable of doing a great job based on the photos the PTC has demonstated in all of it's advertising. However, where does one learn how to do this? How come with all of the classes that PTC offers, there are none for this? I have only had limited sucsess using this and it seems really hit or miss. The problem is time. It takes too long between trials even with a very fast machine. Is there anyone out ther who can set-up simple rooms, colors and textures?
Hi Marvin,
Not sure if this little demo will be helpful for you, but it will at least give you an overview of the current version. I keep hearing that today's rendering technology is much easier to use than ever before.
Also, I am attaching a little PDF with some general best practices for rendering. I am not a technical person myself, but I am sure someone here in this forum will get back to you with more precise information and some tips & tricks soon. I know we have some really experienced ARX users among our customers!!
Bettina
Thanks you for this materials.
Marvin
Thanks for your comments. Attached is a basic Getting Started with Rendering in Pro/ENGINEER Wildfire 5.0 tutorial.
This will walk you throught the steps to create your first rendering
Thank you for this tutorial.
For find more ARX free materials for your renders go to http://www.facebook.com/pages/Creo-ARX/249926328400211
What is exactly LightWorks Material Archives (LWA) is supported?
Camillo
LWA is no longer supported as of Wildfire 5.0 when we switched to Mental Ray as our rendering engine.
Paul Sagar
Director of Product Management, PTC
Paul
Thanks, also i have seen that cubes of preview renders had cool textures and appearance, bu i didn´t find them on the library (like that water)
Best regards
Camilo
The appearances that are supplied with Creo are meant to give you a good starting point. To create the effect of the cube above you will probably want to create a new transparnt glass appearance and then add a procedural bump map to it
Paul Sagar
Hello All,
Please direct me in finding additional HDRI images for use in ARX.
Thank you,
David
The HDR images supplied with Advanced Rendering Extension are supplied by Dosch Design. You can purchase more from www.doschdesign.com.
Alternatively you can search the web and find multiple sources
Paul Sagar
Thank you
