Any way to put a diagonal line though a cell?
Aaronm87
Is there a way to put a diagonal line though a table cell to denote its not used in a drawing? Similar to how you would do it with excel.
tbraxton
(To:Aaronm87)
Yes,
You can add a sketch entity (line) to run across the diagonal of a cell. It is a manual process in dwg mode. If this is something you do often, I would create a drawing symbol for each cell size needed and drop the symbol. I don't think either of these methods are anchored to the table so if the table moves they will be misaligned to the cell.
Involute Development, LLC
Consulting Engineers
Dale_Rosema
(To:Aaronm87)
It is probably not the company standard, but could you add a hyphen "-" instead to designate this or use a back slash "/"?
