Ask for user input when opening part
DerrickVanNieke
8-Gravel
Hi there,
is it possible for CREO, when opening a part have CREO ask for a Length value before creating a part and then creating the part. Family tables won't be effecient for this because the values are one off's and never the same, but all the other values are constant.
thanks,
Derrick
5 REPLIES 5
Assuming the part is going to be used in an assembly, this sounds like a case for making the relevant dimension Flexible.
Hi Derrick,
you can use Pro/Program if you need to customize the prompt (inputs for your part or assembly)
You can find this solution on my model: Parametric gear
Vladimir
Best Regards,
Vladimir Palffy
thanks for the info, I am going to read about it now,
it is not an assembly, it is a sheet metal part.
thanks for taking the time to respond.
I will update my findings here after reading.
thanks.
You are Welcome.
The Pro/Program is really powerfull.
Try to investigate my model (Parametric gear). If you want to edit/manage Pro/Program select: Tools>Program...>Edit Design
The prompt inputs for Parametric gear is between:
INPUT
END INPUT
Vladimir
Best Regards,
Vladimir Palffy
thanks, just downloaded, and will look now.
thanks,
Derrick
