Assembly: Set minimum distance
olliecampbell
I'm building an assembly with various groups and sub-assemblies that I'm using to demonstrate various possible fitment options depending on the arrangement of parts for various scenarios in our product.
There are 4 'standard' measurements that are common between all arrangements that I have setup as features which have associated relations along the lines of:
measurement_id>=SOME_AUTO_CALCULATED_VALUE
At the moment I only have 4 different arrangements, so 12 different 'standard' measurements, but this is due to grow rapidly.
Is there a better way, other than using the distance placement option when assembling, for me to specify a minimum distance between the 2 measurement points?
0 REPLIES 0
