I am having a problem with Pro/E.
I am working with an assembly and I edited a component. When I went back an opened the assembly it asked me if I wanted to update the assembly. I said ok. Then I accidentally hit supress on one component and I got the error messages seen in the photo. I cannot undo changes and the component that is suppressed is now not defined (with mates). How do I go back and just look at the original document before I hit supress?
Thank you for your time,
-Barraza
