Assign Library Material with Family Table
SEaswaran2
9-Granite
Hello alll,
I am trying to assign Material from material library for the instances of a Family Table. Has anyone have idea on this ? Family Table consits of instnaces with different materials. I tried assining density to each instances by using relations and I could create it. Is there a way to assing material from library by using relation to instances of a Family Table?
Thanks in Advance.
Santhosh
Hi
It would be required to add all the materials (needed to be assigned to different instances) to the generic model,
after that in family table parameter "PTC_MATERIAL_NAME" can be selected & drop down menu for the materials already added to generic is available
If you can do this with a native part (no family tables), then you should be able to do this with family tables.
Somehow I suspect that assigning materials using relations is not possible.
Hi
pkhanna,
Thanks for your solution.
Now can I make drop down selection for "PTC_MATERIAL_NAME" as relation. so that it can assign the value for
"PTC_MATERIAL_NAME" based on another parameter say MATERIAL(created by me)
is this possible ?
