BOM tables and FAMILY TABLE INSTANCES...
pkorenkiewicz
Seems I used to know how to do this, but...  Basically I have an assembly with subassembly that is used in two different locations.  Think of a quick release pin with a cable lanyard on it.  The pin and cable hook on in different configurations for the two different locations.  I have created a family table in the subassembly to create the two configurations.  Assembled those into my assembly and created a drawing of the assembly.  When I add my BOM Table to the drawing, it shows the two instances separately.  What I want is for it to show a single line, quantity two, of the pin and cable top generic assembly.  I have tried using the asm.mbr.top_generic bit, but that STILL shows the subassembly on two lines of the BOM.  What am I missing???
thanks in advance!
You can have suppressed components in the generic model and use flexibility to turn them on.
8 REPLIES 8
BenLoosli
(To:pkorenkiewicz)
Perfect example of where flexible components should be used.
The ring and lanyard are a single assembly. When you create a family table, you have created 2 assemblies, so they come into the BOM as 2 items.
By using a flexible component, you can route the lanyard in the assembly for its location and you bring 2 copies of the assembly into your higher assembly. One line item with quantity of 2.
pkorenkiewicz
(To:BenLoosli)
Maybe... though, it's a bit more complicated than that.  I have more than one part that is in a different location, so while I could use flexibility to deal with the cable, it wouldn't work with the other parts...  Attached is a picture of my generic.
Install the generic in your model and use the Components tab of flexibility to turn off those parts not needed.
To take it a step further, apply a predetermined flexibility to the subassembly.
  • File / Prepare / Model Properties / Tools - Flexible - change
  • Add all components you may want to flex off.
You will then be asked if you want to use the predefine flexability when you first add it to your assembly.
pkorenkiewicz
(To:kdirth)
very interesting... never thought to do it this way.   I wonder what the advantage is over family tables?  Other than the obvious, not needing to deal with the BOM table.  Any issues going to pop up when I need to make a drawing of this subassembly?  Can I use flexible models in drawings?  I don't think so, right?  So, then I could always just use component display to blank off one set of duplicates.   Hmmm....
pkorenkiewicz
(To:kdirth)
Thanks... that was the ticket.  I created flexibility in my subassembly to model one configuration, suppressing the components that made up the second configuration.  That way I could use the flexibility in my top assembly to show both configurations.  There were no issues, so far, in the subassembly drawing.  The subassembly only showed one configuration with the second suppressed, so BOM table was correct and BOM balloons displayed as expected.
Thanks kdirth!
StephenW
(To:pkorenkiewicz)
In the past, flexible models had there own set of BOM table issues. I don't use BOM balloons as much as I used to but if things haven't changed, I remember not being able to show balloons on the 2 "different" flexible components.
Also, if you component display/blank, you BOM qty reflects model count, not "blanked" count.
thanks in advance!
I hope someone will help you if you create test data set (simple models+drawing "showing" your problem), pack them into zip file and upload this zip file.
Martin Hanák
